Re: Mini Splits
Posted by WNYBill on October 20, 2023 at 08:16:56 from (72.231.203.117):
In Reply to: Mini Splits posted by dhermesc on October 19, 2023 at 05:01:21:
We have one heat pump what will run 3 air handlers, we only use 2. I couldn't be happier, ours is a Lennox and we had a dealer install it and they do the service. Deep cleaning every other year to keep the 7 year warranty intact, it is >$100. Heats at 100% down to about 0 and then it deteriorates to 0% at -15 degrees. (we have a fuel oil boiler too) AC works great and no noise. You can buy packages through Amazon, HD and Lowes and in new or a garage/unfinished building they would be easy to install. Some come with pre-charged line sets. but I would still want it checked by a professional. I would recommend one heat pump per air handler. About the same price and shorter line sets. Most are designed for exterior installation. A 3-inch hole in the exterior wall and the air handler covers it.
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
