Re: Volts!
Posted by Alberta Mike on May 30, 2003 at 14:43:51 from (209.47.89.121):
In Reply to: Volts! posted by Mike on May 30, 2003 at 10:21:13:
It seems to me that the 550's were factory 12 volt. The smaller 540's started out 6 volts and later were 12 volts. Are you running an alternator (12 volts) conversion or the original generator? I think the generator should say on the tag whether or not it is 6 or 12 volts but I'd say it was factory 12 volts. What exactly do you mean by your reference to the coil being "wired for 6 volts"? A 6 or 12 volt coil would be wired into the system the same. Some might have a resistor before the coil kicking the voltage down to 6 volts but if you have a 12 volt coil that's not necessary. There should be a resistor of that type before the distributor so that only 6 volts is delivered there to the points, otherwise 12 volts can lead to some point burning.
Post A Followup
: Re: Re: Volts!
Today's Featured Article - Using Your Tractor: Creating a Seed Bed - by Chris Pratt. When I bought my first old tractor, I had only one idea in mind. It wasn't the preservation of old iron since at that time, I was unaware that people even did this. It wasn't to show off my restoration skills (though I had tried my hand at a couple of old motorcycles in my teens and if I recall correctly, those old motorcycles were sold in boxes about one quarter finished). It wasn't to relive memories of Grampa, Dad or myself out on the back 40 nursing the Farmall pulling too many b ... [Read Article]
