Tractor Talk Discussion Board |
Re: Massey Diesel Fuel Problem?
Posted by Oldfarmboy Jim on August 03, 2003 at 23:42:57 from (12.80.109.155):
In Reply to: Massey Diesel Fuel Problem? posted by George H on August 03, 2003 at 14:17:18:
Well, don't listen to the mechanics who are pointing to electrical problems. Don't they know it's a diesel for Pete's sake? They run just fine with no electrical system at all! (Unless it's got one of those new fangled injector pumps with electrical shut off solenoids and such. But that's unlikely). Mostly it's one of two things that will cause a diesel to quit when you didn't ask it to. First, is a constriction or blockage in the fuel system. The injector pump has some very small passages that won't tolerate any particulate matter floating in your fuel. The best place to start looking is the filters as the previous gents said. Too often, those things aren't changed for years at a time. If you change the filters, you should also blow out all the fuel lines with compressed air. Make sure there's no loose crap floating around waiting for a place to lodge. Be sure to check the top of the injectors when you remove the fuel lines. Small debris can get trapped in there and intermittently keep fuel from opening the injector. The second reason diesels shut down unexpectedly is if air is somehow introduced into the system. As you probably know, the injector pump puts the fuel up at very high pressure( over a thousand psi in most systems). Trapped air in the injector lines will compress with each stroke of the pump, so the fuel stops moving and doesn't open the injectors. When the tractor is running and at operating temp., look very carefully at all fuel connections and joints to see if any fuel is leaking out in any quantity at all. If fuel can get out, air can get in. Hope you find the problem and it's a smallone. GOOD LUCK, Jim
Home
| Forums
Today's Featured Article -
Trailering Your Tractor - by Curtis Von Fange. One of the fun things of summer and fall are the parades and tractor shows that go on across America. Many owners of tractors travel long distances to attend these shows and they usually take their restored iron along with them. Safe trailering practices and inspections will ensure that the event is a fun one. A good habit to develop when using a trailer is to give that ‘quick look over’ before taking it on a trip. Before hooking up to it check the tongue for proper operation. The latche
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
