Re: Re: Re: Re: Re: ATF vs hydraulic fluid
Posted by Jim on February 15, 2004 at 18:13:39 from (12.28.105.21):
In Reply to: Re: Re: Re: Re: ATF vs hydraulic fluid posted by bruce on February 15, 2004 at 07:37:26:
Bruce, I don't think the air will bleed off without running the machine through all of the functions several times. It sounds like you did that allready, so it may take a couple of more cycles. The leak on the output(pressure) side should'nt be causing the problem,but I would fix it asap. It doesn't take long to pump out 20 gal. if the o-ring/fitting or hose lets go.I will have to look at the shop tomorrow to see if there is a service manual on that old of a machine kicking around, kind of see what the system is, also check for that error in fluid type!Good luck and let me know how it works out.
Jim in N.D.
Post A Followup
: Re: Re: Re: Re: Re: Re: ATF vs hydraulic fluid
