Re: Weight of 1930 Fordson Model N
Posted by Maine Fordson Operator on August 24, 2004 at 14:34:23 from (172.137.199.90):
In Reply to: weight of 1930 fordson posted by mikerbiker on August 23, 2004 at 12:43:07:
Mike: The standard weight of the Model N is 3600 pounds (1636 kg, if you"re in metric-land). Tractor weight will vary, depending on a number of factors: Whether or not the fuel tank & radiator are filled, whether you have the original steel wheels on the rear or if a previous owner equipped it with pneumatic tires; you"ll even see some N"s with the lighter-weight Model F wheels (stamped-steel) on the front instead of the correct cast-iron ones!
Back to your question, though: a trailer with 2-ton capacity is the rig for the job, unless you"re going to be hauling additional spare parts or implements at the same time.
Good luck with your move, and with your N. It"s a great machine, no matter what the green-tractor people say .
-- Rex
Post a Followup
