Re: need info for rebuilding hydrostatic rear
Posted by buickanddeere on September 03, 2004 at 04:57:30 from (192.75.48.150):
In Reply to: need info for rebuilding hydrostatic rear posted by Don Car on September 03, 2004 at 04:36:40:
Try so diagnosing before jumping in. It appears that heat and oil thinning is a factor. Try mounting a pressure test gauge on the ports and find out. Is there an oil cooler that is internally or externally plugged?
Who knows if its dirt, sludge, plugged filter, sump screen, just a worn pump or what. Could just even be the wrong oil accidentally dumped in there.
Odds are a scrapped tractor with a working transmission could be found cheaper than doing a rebuild. These transaxles are common across most brands/models.
Post a Followup
Today's Featured Article - Experimental Tractors Article - by Danny Bowes (Dsl). Tractor technology appears to have nearly hit it's pinnacle of development. If you agreed with the subtitle, you are rather mistaken. Quite, actually. As a matter of fact, some of the technology experimented with over 40 years ago makes today's tractor technology seem absolutely stale by comparison. Experimentation, from the most complex assembly to the most simple and mundane component, is as an integral a part of any farm tractor's development ... [Read Article]
