Re: Making your own hard line hydraulic lines
Posted by Midwest redneck on November 23, 2004 at 08:05:01 from (66.151.2.81):
In Reply to: Making your own hard line hydraulic lines posted by cootbruce on November 23, 2004 at 07:11:08:
Are you piping in a new machine? or a tractor hydro system. I would recommend the following: Use steel lines with flareless fittings, or compression fittings less work, less leaks, also make sure that you size the tubing for the pressure ratings. if the tubing is on a tractor then paint the tubing to prevent rusting.
Post a Followup
