Re: Why does it make noise?
Posted by txgrn on July 16, 2005 at 06:09:56 from (209.151.118.57):
In Reply to: Why does it make noise? posted by kenojoe on July 16, 2005 at 04:33:37:
Called a throwout bearing or clutch release bearing. It's the bearing that pushes against the clutch fingers when you push in the clutch pedal and want to disengage the tranny.
The rumbling is dry worn balls rolling (rumbling) around in the bearing races. Will just get worse and could cause bigger problems if let to where it just flies apart. Could get caught between a spinning clutch and fixed bearing release lever and tear up something.
Takes a housing split; otherwise easy to fix and not expensive.
Mark
Post a Followup
