Re: 6-volt lamp burn out fix on 8-volt systems
Posted by Jim_bobb on October 19, 2005 at 08:24:25 from (69.179.60.49):
In Reply to: Re: 6-volt lamp burn out fix on 8-volt systems posted by Bob on October 18, 2005 at 22:47:42:
Some generator charging systems apply about 9.5 volts to the battery during charging & would idle back to approximately 9 volts once the battery is fully charged. It really depends upon the size of the generator & regulator setting. Some generators are limited to about 9.5 volts output due to the design.
Two diodes will allow .8 volts higher voltage at the lamps. With a generator charging system that averages 9 volts out on a fully charged 8 volt battery, voltage to lamp would be 7.4 volts.
Guessing approximately .4 volts losses in the tractor lighting circuit wiring & light switch would place 7 volts on the lamp. In this case, the 7 volts would afford bright lights without severely limited lamp life.
The problem with 6-volt headlamp brightness is many are only 25-watt bulbs at 6-volts. A 55-watt 12 volt auto type headlamp is much brighter. A pair of 25 watt headlamps tax the generator to about 8 amps at 6 volts and closer to 9.5 amps at 7 volts. Some generators can not supply more than 12-15 amps in an 8-volt system. The higher voltage of 7 to 7.5 volts does make for a brighter headlamp.
Post a Followup
Today's Featured Article - Show Coverage: Journey to Ankeny - by Cindy Ladage. We left Illinois on the first day of July and headed north and west for Ankeny, Iowa. Minus two kids, we traveled light with only the youngest in tow. As long as a pool was at the end of our destination she was easy to please unlike the other two who have a multitude of requirements to travel with mom and dad. Amana Colonies served as a respite where we ate a family style lunch that sustained us with more food than could reasonably fit into our ample physiques. The show at Ankeny ... [Read Article]
