Re: Chains and binders for hauling tractor under 5
Posted by oldfarmtractor on March 20, 2006 at 13:33:39 from (209.7.93.11):
In Reply to: Chains and binders for hauling tractor under 5,000 posted by Nathan in Texas on March 20, 2006 at 13:08:22:
When I tie down a air filled rubber tire, I try to get it so that I actually tie down to something solid like lumber or ??.
I tie it down so that if for some reason, I hit something, the load doesn't go and get me. Hence I try to have one chain to the rear, one to the front and a middle one that is pretty close to straight down but will help keep the load from shifting forward or back.
I have typically bought my chains from auctions. They are cheap and usually in good shape. Take a look if you buy used to see if they have been used to bind bouncing stock. The links might be a bit elongated.
Safety is always a good priority.
