Re: Big 4WDs
Posted by BLUEPAINT on July 07, 2006 at 08:42:55 from (142.161.196.172):
In Reply to: Big 4WDs posted by Cherry Grower on July 06, 2006 at 19:34:22:
With these old girls you should keep it simple , No v8's , Stick with 6 cylinder cummins or even cat , Powershift and auto transmissions can give way more problems than standard ( Stay away from white or case or allis ), Outboard planetaries are a good idea too.
Steiger and versatile are your best bet although the popular models will cost you more ( steiger st 310-325 or versatile 895-936 ) .
But i do have a 1975 steiger bearcat with a cat v8 and i must admit for light work it's been good they are strong tractors but treat that engine with care .
