Tractor Talk Discussion Board |
Re: Problem Solved on noisy 1486 IH
Posted by the tractor vet on August 15, 2006 at 09:40:49 from (75.24.20.100):
In Reply to: Problem Solved on noisy 1486 IH posted by GeneZ on August 15, 2006 at 06:55:37:
Now that ya found the problem here is the way to put it back together also REPLACE the bearing on the PTO input even if ya think it is good replace it along with all new seals . Do not bolt the clutch and pressure plate to the flywheel then trya and make it all line up hang the pressure plate on the PTO input and the clutch disc on the transmission input replace the pilot bearing also at this time . It also helps if you take three 1/4 inch nuts and place then between the face of the pressure plate and the reless finger to hold them down this will allow you to to turn the pressure plate once you have the tractor slide back together then you go up thur the inspection hole and put the pressure plate bolts in two at a time but do not tighten then all the way down till you have them all screwed in and finger tight then rotate and tighten them down evenly two three at a time till they are all holding the plate down then finish tightening them then do the clutch adjustment trans brake adjustment and T/A dunp valve adjustment . If ya need anymore info i will be on the I H board later on this evening.
Home
| Forums
Today's Featured Article -
The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
