Re: Which tractors to recomend
Posted by JMS/MN on January 26, 2007 at 15:02:00 from (204.73.106.15):
In Reply to: Which tractors to recomend posted by alarson on January 26, 2007 at 11:44:50:
You talk about buying 40s-50s- tractor/equipment for $3000. Certainly possible. Full-time farmers ran a quarter section or more back then with the same. You can buy an AC WD, with live hydraulics and live pto for under $1000. Two bottom plow for $150. Seven foot sickle mower for $250. Belly mower for a grand or less. Add a trip-bucket loader for $2-300. Pull type brush hog does not need overrunning coupler or 3pt. Or Farmall, Ford, JD, Oliver, Moline etc. most w/o live power are in the same range. JD 4020 for ten acres? Super overkill, farmers used to run a section or two with that. Mid 50s Case SC with a hand clutch? Any live power?
