Re: JD 400 hydraulic pump drive coupler
Posted by Butcher on July 10, 2007 at 19:27:46 from (4.190.112.209):
In Reply to: JD 400 hydraulic pump drive coupler posted by Curtis Reed on July 10, 2007 at 14:42:56:
Got a 302 that I had to rebuild the hyd. pump 2 years ago. I dont have the service manual at home but they give tourque specs for those bolts. If not reinstalled properly it will give you problems. If I remember right they might also have had some problems with those old couplers. I know this dont help you much but that is one of the worst setups I have ever seen.
Geez, you gotta pull all that crap to change a belt?
