If the air cleaner is an oil bath type, proper servicing should only need the oil bath cleaning out. The operation is that the returning oil from the wire mesh carries the dirt and it is sedimented in the base. If it has been run 'dry' or not been serviced at the proper intervals the mesh will need cleaning carefully - remember, it relies on picking up the oil from the bowl and catching it in the mesh where intimate contact with the induction air leaves the dirt particles sticking in the oil - so as not to leave any path for the induction air, except through the mesh and none where air cannot pass. So be reasonably gentle with it! Regards, RAB
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
