Re: Hydraulic problem
Posted by T on September 20, 2007 at 20:58:59 from (66.44.179.56):
In Reply to: Re: Hydraulic problem posted by Jon Hagen on September 20, 2007 at 17:10:14:
This one has a Cat DT333 engine er so im told... pumpS mount on the left front side of engine, has 2 pumps, one for the remotes and one for the steering system and another in a different location for the transmission....
I shimmed the bypass and found out the high pressure line going to the valve had a rotten spot in it... so now I have a well oiled underside on the cab... gonna get a new hose tomorrow and thin up my shim some, at least I know the pump is good... it has been shimmed b4, I also need to change out a couple leaky quick couplers. do ya know where I can get a rebuild seal kit for the steering cylinders? got one that leaks a fair amount. Thanks for the info.
