Re: 1966 JD 400 pump drive
Posted by DLM on October 06, 2007 at 15:41:20 from (71.219.226.24):
In Reply to: 1966 JD 400 pump drive posted by Ed65 on October 06, 2007 at 06:08:04:
I thought all of the jd400 was the same but might be wrong. WE changed some of them over to a newer style coupling,it is a lot more flexible what it amounts to is a round disk with splines on one side thats bolts to the crank pully and a disk just like that that bolts to the pump shaft and then there is a matching rubber insert that goes between the two disks. If you know what a love joy coupling is it works alot like that.Go to www.johndeere.com click on construction equipment then click on veiw parts catalog and put in 310A find pump drive shaft and you will see the parts. Hope this helps Don
