Re: JD 1120 steering has a lot of play
Posted by Tx Jim on October 22, 2007 at 03:46:58 from (4.253.78.148):
In Reply to: JD 1120 steering has a lot of play posted by RN on October 21, 2007 at 14:59:48:
Have you checked all the tie-rod ends. The ones on the end of the long piece from center to frt. axle also. The bellcrank in center of frt axle has bushings or bearings than can wear out depedending on SN. If valve body itself is loose inside then to repair it has to come apart. Tx Jim
