I have also hauled cars with the wheel lift on my 4 car carrier,, you can legally and safely use the straps because it is a vertical pull on the tires, into the cradle of the wheel lift,,
the tire sits in the cradle, and is secured with the strap as a safety measure,, pulling against the center of the tire DOWN,, so there is no rolling action going on,, there is no back and forth momentum,,
so in reality it is not the same force as securing a tractor [or car for that matter] on a platform [deck of trailer or rollback]
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
