Re: OT 93 Bonneville Converter Lockup Question
Posted by Brokenwrench on March 03, 2008 at 09:56:07 from (75.100.176.16):
In Reply to: OT 93 Bonneville Converter Lockup Question posted by ribbitt on March 03, 2008 at 07:59:50:
Sounds right to me. You may as well not look at what the shop manual suggests. GM has about 50 different calibration proms for the PCM. I`ve had em where they won`t lock-up til 60-62mph. That was GMs early fix to shudder problems. Most GM front wheel drives won`t command lock-up til over 40-45mph.
The TCC should unlock at closed throttle, otherwise you can get those on the gas, off the gas drivers that can really make the car start to buck. There`s nothing you can do in the trans to change lock-up timing or release, 100% computer commanded. Good luck and keep driving her, those are great cars. BW
