How to install a bearing in a cast iron pillow block
Posted by Ryan - WI on March 14, 2008 at 06:32:25 from (216.56.60.115):
I have to fix a spreader for a colleague today. To do so I need to get a bearing pressed into a fs207 cast iron pillow block. It appears that I need to heat the block and freeze the bearing. Is that correct? I don't want to end up breaking the cast iron. Will that give me enough clearance? Should I heat the block in the oven or with a torch?
