The temperature went wacky on a Pontiac mini van with the no-account 3.4 engine we used to own. To get an opinion, I went to the Service Dept. at the Chevy dealer we usually dealt with. The Service Manager right away said on the 3.4 it would be the head gaskets failed and estimated $1500 to replace them. UNLESS one or both of the heads were cracked, then it would be an extra several hundred dollars more per head.
I said I need a second opinion and went to an independent shop I've also dealt with. They found the radiator cap wouldn't hold pressure. An $8.00 radiator cap is a bit different from a head gasket job.
I don't want to burn bridges with that Chevy dealer because I have a good deal going with the Parts Dept. and one of the salesmen is an old friend, but I discreetly no longer have anything to do with the Service Dept.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
