Vacuum seems ok since I did all this with the air clearer hose off and held my hand over the intake and it sucked pretty hard. I did open up the carb and it does look bad so I figure if I get lucky that will be the problem. If after a carb rebuild that does not fix the problem I'll move on to other theings. I need this little crawler at this time to clear out a fence row so I can do a new fench. This fence row is full of thorns so I want to use a track machine to clear it out not a tire machine
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
