Re: John deere gt 275 wont start
Posted by RAB on June 26, 2008 at 08:31:06 from (195.93.21.10):
In Reply to: John deere gt 275 wont start posted by 443754 on June 26, 2008 at 07:48:39:
Lanse - he said into the intake so presumably valve gear is OK.
Could be a blocked carb or could be an air leak into the inlet manifold. Is the choke working correctly?
The plugs should be wet after cranking and not starting. If they are dry start working back towards the carb.
Regards, RAB
