Re: 8N with no compression in rear two cylinders
Posted by Bob on August 10, 2008 at 11:13:27 from (69.178.228.68):
In Reply to: 8N with no compression in rear two cylinders posted by MarkR. on August 10, 2008 at 11:10:25:
You have either a couple of stuck valves or a blown headgasket.
Start by removing the rear sidecover on the RH side of the engine. You can then watch the valve action while cranking and see which, if any, valves are stuck.
