Re: Tips on skidding logs (Tops)
Posted by buickanddeere on August 26, 2008 at 08:26:33 from (192.75.48.150):
In Reply to: Tips on skidding logs (Tops) posted by JW Axtell on August 25, 2008 at 18:09:40:
It's oak and pretty heavy.
This involves dragging them some distance.
Straddle the log with the 3 point then chained and raised the end up. Keep the butt from catching.
With full weight on a raised three point hitch. That 9N will be up, over and on top of you the 1st time the butt of the log catches something solid.
Fire department pulled a ford off a neighbout two years ago. He was the lucky exception and excaped with bumps nd bruises. Happened to be pulling maple tops in the bush/forest/woods.
Pulling from a drawbar would be safer.
As previously stated unless you are using a grab/slide hook and a couple wraps of chain. The log is going to slide.
