I live in VA also and did this. Bet ya he wants to pay a percentage by weight or board feet of what he gets. WRONG APPROACH. Hire a timber broker! First he will advise you how to do this. If he takes it on he will survey the plot and then auction the timber off. Then supervise the cutting. AND you can have a select cut where only greater then or smaller then a set size are cut. Under these conditions the cutter is responsible for damage to uncut tress--within reason. Good Luck
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
