Re: More info on Bobcat 773
Posted by JCSinGA on September 07, 2008 at 10:24:25 from (98.18.102.242):
In Reply to: More info on Bobcat 773 posted by Tim of PA on September 07, 2008 at 09:02:04:
Ok what series machine is it? C,F or G, the C & F had locks on the pedals via a small white pad that just pushed down when the safety bar was lowered, over time they do wear and will get to the point that they wont unlock the pedal.
The G series is more complicated in that it uses voltage from the on board computer to unlock the pedals thru a small solenoid at the control valve but it should also be throwing a code at you as a clue as to whats wrong.
Very likely it wont be a mechanical problem within the control valve thats causing the problem more likely a problem with the mechanical pedal lock.
