Re: 54 8N No throttle
Posted by old on September 27, 2008 at 19:41:58 from (4.245.2.101):
In Reply to: 54 8N No throttle posted by Todd 22 on September 27, 2008 at 18:39:26:
Well first off you need to figure out what you have. Lat year an 8N was made with front mount distributor was early 1950. So then does it have a 3 or 4 speed tranny?? If its a 4 speed then yes its an 8N if its a 3 speed its either a 9N or 2N. As far as throttle that could be linkage not hooked up like it should be and or a bad spring some place
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
