Posted by Walt davies on November 23, 2008 at 10:23:18 from (75.106.198.236):
In Reply to: Tire chain install? posted by Rusty machinist on November 23, 2008 at 09:25:21:
Tires chain should be loose to work properly. Lay the chain down in front of the tire drive over it just enough to be able to hook the ends together. then pull it over the top and hook the ends, inside first. A small amount of tension on the outside chain but the ones that go over the tire to the other side should be loose to grab in. Don't let the air out and then tighten them up with more air this only ruin the tires and they will work at about half their efficiency. Walt
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
