Re: starting problems
Posted by El Toro on January 05, 2009 at 11:45:41 from (205.188.117.74):
In Reply to: starting problems posted by Phil Reynolds on January 05, 2009 at 08:09:42:
Pull the starter and see if the teeth are missing or worn on the ring gear. Could the ring gear has been spinning that's been suggested. Use a pinch bar and see you can move the engine freely.
Your starter may need to be load tested, could the bendix drive is the culprit. Hal
