Re: Anyone make there own hayrack?
Posted by Paul from MI on February 05, 2009 at 18:42:38 from (74.204.65.48):
In Reply to: Anyone make there own hayrack? posted by GoJDpuller on February 05, 2009 at 16:11:26:
I have built several using old homemade running gears. Gears had old car front axles, which tells you how cheap I am. I used treated 4x6s for the stringers and treated 2x4s for the cross supports. 2x2x1/8 angle iron makes a good means to fasten them to the stringers. The deck was made from 5/4x6 deck lumber laid lengthwise. I used a 5/4x2 strip all around the edges to help keep the bales from sliding. Size can be to suit, but I made them 7-1/2' x 15'. I could easily get 96-100 bales on them, more if needed. With some homemade side boards they doubles as ear corn wagons. Fasten everything with deck screw to prevent corrosion.
Paul
