Re: OT: 91 Buick regal fuel pump.
Posted by Lou from Wi. on June 29, 2009 at 20:20:52 from (174.124.85.77):
In Reply to: OT: 91 Buick regal fuel pump. posted by Balaton17 on June 29, 2009 at 18:07:19:
My son who is familar with such,says to check filter and gas tank vent. or fuel pressure regulator. All or one will cause speratic failure. Hope this helps.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
