Posted by 55 50 Ron on November 03, 2009 at 11:16:56 from (206.8.2.145):
In Reply to: Re: Chevy truck mechanic posted by BDT in Minnesota on November 03, 2009 at 08:50:01:
Yes, I replaced it with a new brass plug. But the old one was brass also.
To get the old one out I used a couple of different diamond cutting bits in an angled drill and cut away part of the boss on the block. Sprayed with Kroil a few times and let it set. One diamond cutting bit was 1/8 inch diameter and with it, I cut straight down from the top until that bit was into the center of the brass plug where the broken off drill bit remained. Then I squeezed gently from the sides with a small visegrip pliers and the brass plug sides moved inward just enough to be able to turn it slowly. Then it was easy to pull the broken bit out. Ran a tap in the boss threads and put in the new plug. The block is still full of crud, but I'll get that cleaned another time.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
