Re: farmall h start
Posted by Goose on November 11, 2009 at 20:03:48 from (67.63.68.13):
In Reply to: Re: farmall h start posted by GordoSD on November 11, 2009 at 17:25:07:
A month or so ago, my H wouldn't respond to the throttle setting. Might run fast with the throttle in the idle position, or vice versa and wouldn't speed up when the throttle was pulled back.
Turned out the linkage inside the governor was severely gummed up and sticking. Took the cover off the governor, soaked it in WD40 to free it up, blew air through the tube to the cylinder head and put the cover back on. No more problem.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
