Re: Excessive oil consumption???
Posted by jdemaris on November 18, 2009 at 14:06:55 from (67.142.130.25):
In Reply to: Excessive oil consumption??? posted by dave2 on November 18, 2009 at 12:56:14:
If it was a "classic valve seal" problem, it would only be using oil at first start, or while coming downs steep hills with a low gear holding you back.
Gas engine has vacuum pulling oil through the valve stems. I assume your diesel engine does not. Very few diesels have vacuum. A few old ones with air-governors do - e.g. a Fordson diesel or IH B-275.
Scored cylinder walls and/or worn top piston ring-grooves will cause excess smoke at starting along with high oil consumption. If you actually ran this thing out of oil once, I suspect that is the problem
