Mike, with only 350 hours I'd think it is still under warranty. That being said if you lift the hood and have someone turn on the switch you should be able to see the fuel solenoid actuate. Its probably located on the right side of the engine (from the drivers set)near the fuel tank. It is actuating or it wouldn't start at all. Watch it to see if it shuts off when the switch key is released. I'm not sure but there may be a fuse somewhere in that system or it may be the switch is bad. After diesels start there is only one reason they won't run and that is lack of or no fuel.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
