Posted by 4430jd on January 02, 2010 at 17:14:26 from (68.30.151.250):
In Reply to: Pond Dam Leaking posted by Steve in IL on January 01, 2010 at 15:09:52:
I have fixed several different ways, You can try Bentonite applied by Broadcasting over the water will work on small leak, Best way is to pump down pond and at the leak area and dig out soft material and replace with good clay compacted in, and some Bentonite mixed in with it will help ensure a good job, If after pumping down you cant tell where the leak is till up the area with disc and pack back down,Depending on your pond and what materials you have to work with you can also line the pond with a foot of clay, or two feet of topsoil to seal it off,
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha
... [Read Article]
Latest Ad:
[More Ads]
