Re: Of grooved shafts leaky oil seals (pic)
Posted by Janicholson on January 22, 2010 at 07:52:21 from (199.17.6.222):
In Reply to: Of grooved shafts leaky oil seals (pic) posted by kestrel on January 22, 2010 at 07:38:07:
I also recommend a speedy sleeve. The shaft could be turned down on the OD and polished, then a different seal could be used with the same OD and a smaller ID. This would not affect the taper fit of the output, and might be an option if the Speedy sleeve can't be found of the correct size. JimN
