Posted by 1950ish on February 05, 2010 at 08:46:45 from (209.50.26.76):
In Reply to: Wards Grainbuster posted by ryanwheelock on February 04, 2010 at 05:50:13:
I'll try to answer your question, but excuse the terminology. The square opening on the one side is the the inlet for air to carry away the ground product. On opposite side, the "tube" carries the material up into the blower, to be blown up the round duct to the cone-shaped part. The ground material swirls around in the cone, and settles to the bottom, and out the chute. At the same time, the air is exhausted out the top of the cone. If the pulley on your tractor is 1 1/2 times the size of the grinder pulley, grinder RPM's should be about right.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
