Re: installing a alternator
Posted by JMOR on May 11, 2010 at 07:13:37 from (72.181.166.200):
In Reply to: installing a alternator posted by gitrib on May 11, 2010 at 06:56:47:
mss3020 said: (quoted from post at 09:56:47 05/11/10) Im installing an alternator in a Case 1830 that didnt have one when I bought it. So I have the alternator with three wires from it the Big red one, the #1 and the #2 which are side by side. I have a amp meter that I need to put in this config somehow..I have looked on google but there are alot of different ways it seems to hook the #1 and #2. I know the big red one goes to the battery. after that give me some guidence. thanks
Connect the big red one (BATT/alt output) to battery (probably not directly to battery post, but to tie point where all loads are sourced from battery). Connect #2 to BATT/alt output)..your big red wire. Connect #1 to a small light bulb such as a trailer side marker bulb. Connect the other side of that bulb to the side of ignition switch that is hot when Ignition is ON. Want an ammeter? It is connected in series with the wire supplying all loads from the battery (except the starter).
