Re: vehicle airbag detonation, only via an electric signa...
Posted by Brian Jasper co. Ia on May 23, 2010 at 18:46:49 from (67.142.130.33):
In Reply to: vehicle airbag detonation, only via an electric signal??? posted by buickanddeere on May 23, 2010 at 10:05:56:
ALL vehicles have a module that makes the decision based on sensor input to deploy the air bag(s). Static electricity can do it. Next time you have an airbag connector disconnected, look into the 2 halves. The bag side of the connector will have a shorting bar that shorts the 2 terminals together when disconnected. The shorting bar also helps protect someone from trying to put an ohm meter across the bag and deploying it.
