Re: Super WD9
Posted by Mike (WA) on June 27, 2010 at 09:59:25 from (69.10.196.7):
In Reply to: Super WD9 posted by Ethan Chamberlain on June 27, 2010 at 09:51:45:
I know everybody is death on EZ-outs, but in this case, I think it would work. Bust the porcelain on the plug, and drill it out so you can use a nice big EZ-out. Spark plugs aren't torqued in as hard as most bolts, and with the large EZ out, you should be able to get it.
And try a combination of ATF and acetone in the cylinders- somebody did a study, and that combination worked better than PB Blaster, Kroil or anything else. Old has been a proponent of ATF for that purpose for years, and adding acetone will make it even better.
