Re: 3414 industrial backhoe carb trouble
Posted by sotxbill on July 08, 2010 at 14:55:53 from (76.227.27.16):
In Reply to: 3414 industrial backhoe carb trouble posted by In a mess on July 08, 2010 at 10:38:39:
are you talking about the needle valve that is on the float???(inside bowl, lets gas into the bowl for the carb to use) or the high speed jet, or the low speed air adjustment?
The float needle valve can have a small spring on it between the float and the needle. if it does,, you will see where the needle is machined down for the small spring to sit on it. Some carb rebuild kits come with the new style some with the old style. As long as it cuts off the gas at the correct height of fuel in the bowl, I dont think it matters much.
Hope my answer is close.. thx bill
