Re: olds pickup update?
Posted by Tom in TN on July 10, 2010 at 12:12:43 from (4.152.159.171):
In Reply to: Re: olds pickup update? posted by old on July 10, 2010 at 07:44:38:
This is not a suggestion - just a statement of fact. I had a 1972 Buick back in the early 80's. It would stall, then after a while it would start and run well for a while and then stall. After way too much messing with it, and being left stranded way too many times, I found a crack in the flexible fuel line that went up over the differential. Replaced about fifty cents worth of fuel line and never had a bit of trouble out of it again.
Those intermittent problems are by far the hardest to fix. Don't you wish it would break completely and just let you fix it?
Good luck,
Tom in TN
