I've loosened most every fitting,, no fuel flow. To get flow through the pump (low pressure) it shouldn't have anything to do with the high pressure side. I already had the top cover off and the governor control is moving as it should be. Pump is turning, I checked it with the fuel transfer pump off, so I'm sure it's turning. I already had the idea as someone else suggested to use an electric fuel pump just to check it out, but I still have to figure out why the transfer pump isn't pumping. So far, I feel its just a wear issue, as I understand replacing the vanes is quite common.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
