Posted by John S-B on August 16, 2010 at 14:45:12 from (64.12.116.74):
Well I'm finally home so I gotta catch up on things. I need to get the chipper going but it hasn't been used in about five years so natch the carb is shot. I need to rebuild it but I don't see any ID on the engine. The carb has the number 1071 1L stamped under the idle adjust screw on the top. (I think the last thing is an "L") It's of of a 8HP engine, and it's about 22-25 years old. There is a needle screw that comes up through the bottom of the fuel bowl and another adjustment screw just above the bowl on the same side as the idle adjust screw. (I think it adjusts the idle, it contacts a tab on the throttle lever) Any help would be appreciated.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
