Re: Confirm my farmal Cub fuel supply problem
Posted by Old Roy on September 05, 2010 at 00:38:05 from (98.17.220.74):
In Reply to: Confirm my farmal Cub fuel supply problem posted by kootenay cub on September 04, 2010 at 20:01:30:
you say the outlet line is leaking --- It probably starts sucking air , causing it to stall sounds like you either have the float level set wrong or the needle valve needs taken out and cleaned -- check the seat for dirt when ya got it out .
