Re: Grading a gravel driveway
Posted by Showcrop on September 21, 2010 at 11:59:44 from (75.67.231.80):
In Reply to: Grading a gravel driveway posted by Chuck one on September 21, 2010 at 10:42:22:
If your driveway is very long or you are looking at maintaining it for a few years, You would be way ahead by taking the blade to a fabricator and having a gauge wheel added to the back. A set-up with a screw adjust would be nice but one with simple adjustment by washers like on the back of a shredder would work well. With this arrangement the blade is vertically positioned by the smoothed ground instead of the rough stuff. Same idea as a road motor grader. Another plus is that you can still tilt the blade with the leveling box crank so you can crown your driveway, making the water run to the sides, slowing pothole formation.
