Argon is heavier than air. You shouldn't do any welding with either in a confined space without a proper respirator and/or fresh air supply. It isn't uncommon for welders that do a lot of TIG welding with pure argon to stand on their heads after welding for a few hours to let the argon get out of their system. CO2 displaces oxygen. Dave
Health effects of argon Routes of exposure: The substance can be absorbed into the body by inhalation.
Inhalation risk: On loss of containment this liquid evaporates very quickly causing supersaturation of the air with serious risk of suffocation when in confined areas.
Effects of exposure: Inhalation: Dizziness. Dullness. Headache. Suffocation. Skin: On contact with liquid: frostbite. Eyes: On contact with liquid: frostbite.
Inhalation: This gas is inert and is classified as a simple asphyxiant. Inhalation in excessive concentrations can result in dizziness, nausea, vomiting, loss of consciousness, and death. Death may result from errors in judgment, confusion, or loss of consciousness which prevent self-rescue. At low oxygen concentrations, unconsciousness and death may occur in seconds without warning.
The effect of simple asphyxiant gases is proportional to the extent to which they diminish the amount (partial pressure) of oxygen in the air that is breathed. The oxygen may be diminished to 75% of it's normal percentage in air before appreciable symptoms develop. This in turn requires the presence of a simple asphyxiant in a concentration of 33% in the mixture of air and gas. When the simple asphyxiant reaches a concentration of 50%, marked symptoms can be produced. A concentration of 75% is fatal in a matter of minutes.
Symptoms: The first symptoms produced by a simple asphyxiant are rapid respirations and air hunger. Mental alertness is diminished and muscular coordination is impaired. Later judgment becomes faulty and all sensations are depressed. Emotional instability often results and fatigue occurs rapidly. As the asphyxia progresses, there may be nausea and vomiting, prostration and loss of consciousness, and finally convulsions, deep coma and death.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
[More Ads]
